Suzuki Grand Vitara XL7 2.0TD RHW ECU(Beyin) Arıza Kodları
Gönderilme zamanı: 29 Mar 2019 11:51
GRAND VITARA XL-7 2.0 HDI ECU RHW Engine (EOBD Spec)
https://www.obd-codes.com/
ENGINE:
DTC P0100 (P0102 / P0103 / P3007 / P3008): Mass Air Flow Circuit (Low Input / High Input / Plausibility at Low Flow / Plausibility at High Flow)
DTC P0110 (P0112 / P0113): Intake Air Temperature Sensor Circuit (Low / High)
DTC P0115 (P0115 / P0117 / P0118): Engine Coolant Temp. (ECT) Sensor Circuit (Malfunction / Low / High)
DTC P0220 (P0222 / P0223 / P0224) / P2299: Pedal Position Sensor Circuit Malfunction
DTC P0180 (P0182 / P0183): Fuel Temperature Sensor Circuit (Low / High)
DTC P0190 (P0192 / P0193 / P0194): Fuel Rail Pressure Sensor Circuit (Low / High / Intermittent)
DTC P0089 (P0089 / P0087, P1113 / P0088, P1116 / P0094): Fuel Pressure Regulator Performance (Malfunction / Fuel Rail Pressure Too Low / Too High / Fuel System Leak Detected - Small Leak)
DTC P0201 (P0201 / P0261 / P0262 / P1372): Injector Circuit - Cylinder 1 (Malfunction / Low / High / Short)
DTC P0202 (P0202 / P0264 / P0265 / P1373): Injector Circuit - Cylinder 2 (Malfunction / Low / High / Short)
DTC P0203 (P0203 / P0267 / P0268 / P1374): Injector Circuit - Cylinder 3 (Malfunction / Low / High / Short)
DTC P0204 (P0204 / P0267 / P0268 / P1374): Injector Circuit - Cylinder 4 (Malfunction / Low / High / Short)
DTC P1169 / P1170: Condenser Voltage Too Low / High
DTC P0215: Engine Shutoff Solenoid
DTC P0230: Fuel Pump Primary Circuit
DTC P0243 (P0243 / P0246) / P0245 (P0245): Turbo Charger Waste Gate Solenoid (Malfunction / High) / Turbo Charger Waste Gate Solenoid Low
DTC P0234 (P0234) / P0299 (P0299): Turbo Charger Over Boost Condition / Under Boost
DTC P0380 (P1351 / P1352 / P1349 / P1350) / P1404: Glow Plug Circuit Malfunction
DTC P0381: Glow Plug Indicator Circuit
DTC P0401 (P0401): Exhaust Gas Recirculation Flow Insufficient Detected
DTC P0400 (P0400 / P0402 / P2143 / P2145) / P2144 (P2144): Exhaust Gas Recirculation Flow Malfunction
DTC P0105 (P0107 / P0108): Barometric Pressure Sensor Circuit (Low Input / High Input)
DTC P0561 (P0642 / P0643): Sensor Reference Voltage Circuit (Low / High)
DTC P0603 (P0603) / P0604 (P0604): Internal Control Module Keep Alive Memory (KAM) Error / Random Access Memory (RAM) Error
DTC P1107 (P2009 / P2010): Intake Manifold Runner Control Circuit (Low / High)
DTC P0480: Fan 1 Control Circuit
DTC P0481: Fan 2 Control Circuit
DTC P3004 (P3005 / P3006): 3rd Piston Deactivator Circuit (Short / Open)
DTC P0090 (P0090 / P0091 / P0092): Fuel Pressure Regulator Control Circuit (Malfunction / Low / High)
DTC P0606 (P0606) / P1171: ECM Processor / ECU Function (ECU Internal Fault)
DTC P0120 (P0487 / P2142) / P2141 (P2141): Exhaust Gas Recirculation Throttle Position Control Circuit (Malfunction / High) / Low
DTC P1511: Ignition Switch Circuit Malfunction
DTC P0485: Fan Power / Ground Circuit
DTC P0650 (P0650 / P1642): Malfunction Indicator Lamp (MIL) Control Circuit Malfunction (Malfunction / Open)
DTC P0608 (P0658 / P0659): Actuator Supply Voltage Circuit 1 (Low / High)
DTC P0609 (P2670 / P2671): Actuator Supply Voltage Circuit 2 (Low / High)
DTC P0225 (P0224 / P0227 / P0228 / P2137): Pedal Position Sensor “No.2” Circuit (Intermittent / Low / High / Voltage Correlation)
DTC P0335 (P0335): Crankshaft Position Sensor Circuit
DTC P0340 (P0340 / P0343 / P0344 / P0016): Camshaft Position Sensor Circuit (Performance / High / Intermittent / Crankshaft Position - Camshaft Position Correlation)
DTC P0500 (P0500 / P0501): Vehicle Speed Sensor (VSS) (Malfunction / Performance)
DTC P0235 (P0069 / P0235, P1281 / P0237 / P0238): Turbo Charger Boost Sensor Circuit (Manifold Absolute Pressure - Barometric Pressure Correlation / Malfunction / Low / High)
DTC P0560 (P0562 / P0563): System Voltage (Low / High)
DTC P1613: ECM Not Registered
DTC P1517: Immobilizer System Malfunction
RHW Engine (Other than EOBD Spec)
ENGINE:
DTC P0100 (P0100): Mass Air Flow (MAF) Sensor Circuit Malfunction
DTC P0101 (P0100): Mass Air Flow (MAF) Sensor Circuit Range / Performance Problem
DTC P0110: Intake Air Temp. (IAT) Sensor Circuit Malfunction
DTC P0115 (P0115): Engine Coolant Temp. (ECT) Sensor Circuit Malfunction
DTC P0121 (P0120) / P0604 (P0120): Throttle Position (TP) Sensor Circuit Malfunction
DTC P0180: Fuel Temperature Sensor Circuit Malfunction
DTC P0190 (P0190): Fuel Rail Pressure Sensor Circuit Malfunction
DTC P0191 (P0230) / P1112 (P0230): Fuel Rail Pressure Sensor / Pressure Regulator Malfunction
DTC P0201 (P0200) / P0202 (P0200) / P0203 (P0200): Injector Circuit Malfunction Cylinder 1 / Cylinder 2 / Cylinder 3 / Cylinder 4
DTC P0215: Double Relay Circuit Malfunction
DTC P0230: Fuel Pump Supply Circuit Malfunction
DTC P0243 (P0243): Turbo Pressure Solenoid Valve Circuit Range / Performance Problem
DTC P0245 (P0243) / P0246 (P0243): Turbo Pressure Solenoid Valve Circuit Range / Performance Problem
DTC P0380 (P0380) / P1404 (P0380): Pre / Post Heat Relay Circuit Malfunction
DTC P0381: Glow Indicator Lamp Circuit Malfunction
DTC P0401 (P0903) / P0402 (P0903): EGR Solenoid Valve Flow Insufficient Detected / Excessive Detected
DTC P0403 (P0403): EGR Solenoid Valve Circuit Malfunction
DTC P0561 (P0560): Stabilization of Sensor Supply
DTC P1107: Swirl Control Solenoid Valve Circuit Malfunction
DTC P1108: Radiator Fan High Speed Circuit Malfunction
DTC P1109: Radiator Fan Low Speed Circuit Malfunction
DTC P1110: A/C Signal Circuit Malfunction
DTC P1135: 3rd Piston Deactivator (Injection Pump Solenoid Valve) Circuit Malfunction
DTC P1138 (P0230): Fuel Pressure Regulator Circuit Malfunction
DTC P1402 (P0510): Throttle Solenoid Valve Circuit Malfunction
DTC P1519: Radiator Fan Circuit Malfunction
DTC P1606: MIL Circuit Malfunction
DTC P1608: ECT Warning Lamp Circuit Malfunction
DTC P1614 (P0560): Sensor Supply Function
DTC P0221 (P0220): Throttle Position Range / Performance Problem 2
DTC P0335 (P0335): Crankshaft Position Sensor Circuit Malfunction
DTC P0340 (P0335 / P0340): Camshaft Position Sensor Circuit Malfunction
DTC P0500 (P0500): Vehicle Speed Sensor (VSS) Circuit Malfunction
DTC P0235 (P0235): Intake Air Pressure Sensor Circuit Malfunction
DTC P0560 (P0560): Power Supply Circuit Malfunction
DTC P0603 / P0606 / P1171: ECM Function
DtC P1169 (P0170) / P1170 (P0170): Condenser Valve Function 1 / Function 2
DTC P1101 (P0105): Barometric Pressure Sensor Circuit Malfunction
BRAKES
DTC C1013 (No. 13): System Specifications Different from ABS Control Module Specifications
DTC C1015 (No. 15): G Sensor Circuit and 4WD Circuit
DTC C1021 / C1022 / C1025 / C1026 / C1031 / C1032 / C1035 / C1036 (No. 21 / 22 / 25 / 26 / 31 / 32 / 35 / 36): Wheel Speed Sensor Circuit
DTC C1041, C1045, C1055 / C1042, C1046, C1056 (No. 41, 45 / 56): Inlet Solenoid / Outlet Solenoid Circuit
DTC C1057 (No. 57): Power Source Circuit
DTC C1061 (No. 61): ABS Pump Motor Circuit
DTC C1063 (No. 63): ABS Fail-Safe Relay Circuit
DTC C1071 (No. 71): ABS Control Module
Automatic Transmission/Transaxle
DTC P0705 (No.34): Transmission Range Sensor Circuit Malfunction
DTC P0717 (No.14): Input / Turbine Speed Sensor Circuit No Signal
DTC P0722 (No.31): Output Speed Sensor Circuit No Signal
DTC P0741 / P0742 (No. 78 / 77): TCC Circuit Performance or Stuck OFF / Stuck ON
DTC P0751 / P0752 (No. 62 / 61): Shift Solenoid-A Performance or Stuck OFF / Stuck ON
DTC P0973 / P0976 / P0985 (No.22 / 24 / 49): Shift Solenoid “A” Control Circuit Low / “B” Control Circuit Low / “E” Control Circuit Low
DTC P1740 (No.75): Cruise Control Signal Malfunction
DTC P1875 (No.15): 4WD LOW Switch Circuit Malfunction (Open)
DTC P0707 (No.34): Transmission Range Sensor Circuit Low
DTC P0711 (No.81): Transmission Fluid Temperature Sensor Range / Performance
DTC P0712 (No.38): Transmission Fluid Temperature Sensor “A” Circuit Low
DTC P0713 (No.36): Transmission Fluid Temperature Sensor “A” Circuit High
DTC P0756 / P0757 (No.65 / No.63): Shift Solenoid-B Performance or Stuck OFF / Stuck ON
DTC P0771 / P0772 (No.67 / No.66): Shift Solenoid-E Performance or Stuck OFF / Stuck ON
DTC P0781 (No.68): 1-2 Shift
DTC P0797 (No.79): Pressure Control Solenoid “C” Stuck ON
DTC P0962 / P0966 / P0970 (No.41 / 43 / 45): Pressure Control Solenoid “A” Control Circuit Low / “B” Control Circuit Low / “C” Control Circuit Low
DTC P0963 / P0967 / P0971 (No.42 / 44 / 46): Pressure Control Solenoid “A” Control Circuit High / “B” Control Circuit High / “C” Control Circuit High
DTC P0974 / P0977 / P0986 (No.21 / 23 / 48): Shift Solenoid “A” Control Circuit High / “B” Control Circuit High / “E” Control Circuit High
DTC P1701 (No.76): CAN Communication Problem - TCM
DTC P1702 (No.83): Internal Control Module Memory Check Sum Error
DTC P1703 (No.86): CAN Invalid Data - TCM
DTC P1874 (No.15): 4WD Low Switch Circuit Malfunction (Short)
DTC P2742 (No.59): Transmission Fluid Temperature Sensor “B” Circuit Low
DTC P2743 (No.58): Transmission Fluid Temperature Sensor “B” Circuit High
DTC P2763 (No.26): Torque Converter Clutch (TCC) Circuit High
DTC P2764 (No.25): Torque Converter Clutch (TCC) Circuit Low
Air Conditioning System
DTC B1501 (No.01): Outside Air Temperature Sensor and Its Circuit Malfunction
DTC B1502 (No.02): Inside Air Temperature Sensor and Its Circuit Malfunction
DTC B1503 (No.03): A/C Evaporator Temperature Sensor and Its Circuit Malfunction
DTC B1504 (No.04): Sunload Sensor and Its Circuit Malfunction
DTC B1510 (No.10): Engine Coolant Temperature (ECT) Sensor and Its Circuit Malfunction
DTC B1511 (No.11): Temperature Control Actuator (Position Sensor) and Its Circuit Malfunction
DTC B1512 (No.12): Air Flow Control Actuator (Position Sensor) and Its Circuit Malfunction
DTC B1513 (No.13): Temperature Control Actuator and Its Circuit Malfunction
DTC B1514 (No.14): Air Flow Control Actuator and Its Circuit Malfunction
DTC B1520 (No.20): Temperature Selector and Its Circuit Malfunction
DTC B1521 (No.21): Blower Speed Selector and Its Circuit Malfunction
DTC B1522 (No.22): Air Flow Selector and Its Circuit Malfunction
Air Bag System
DTC B1015: Passenger Air Bag Initiator Circuit Resistance High
DTC B1016: Passenger Air Bag Initiator Circuit Resistance Low
DTC B1018: Passenger Air Bag Initiator Circuit Short to Ground
DTC B1019: Passenger Air Bag Initiator Circuit Short to Power Circuit
DTC B1021: Driver Air Bag Initiator Circuit Resistance High
DTC B1022: Driver Air Bag Initiator Circuit Resistance Low
DTC B1024: Driver Air Bag Initiator Circuit Short to Ground
DTC B1025: Driver Air Bag Initiator Circuit Short to Power Circuit
DTC B1031: Power Source Voltage High
DTC B1032: Power Source Voltage Low
DTC B1035 / B1037: RH / LH Forward Sensor Circuit Open or Short to Ground
DTC B1036 / B1038: RH / LH Forward Sensor Circuit Short between Two Wires or Short to Power Circuit
DTC B1041 / B1045: Driver / Passenger Pretensioner Initiator Circuit Resistance High
DTC B1042 / B1046: Driver / Passenger Pretensioner Initiator Circuit Resistance Low
DTC B1043 / B1047: Driver / Passenger Pretensioner Initiator Circuit Short to Ground
DTC B1044 / B1048: Driver / Passenger Pretensioner Initiator Circuit Short to Power Circuit
DTC B1051: Frontal Crash Detected (System Activation Command Outputted)
DTC B1061: “AIR BAG” Warning Lamp Circuit Failure
DTC B1071: Internal SDM fault
DTC B1013: System Specifications Different from SDM Specifications
Body Electrical Control System
DTC B1121: DRL Circuit Malfunction
DTC B1131: Illumination Control Input Circuit Open (H27 Engine Model Only)
DTC B1141 / B1142: Outside Air Temperature (Ambient Temp.) Sensor Circuit Open / Short to Ground
DTC B1156: CAN Communication Error (H27 Engine Model Only)
DTC B1170 / B1171 / B1172: Factory Register Error / Memory Check Sum Error / Memory Write Error
Immobilizer Control System
DTC 11 / 31: Transponder Code Not Matched / Not Registered
DTC 12: Fault in Immobilizer Control Module
DTC 13 / 14: No Transponder Code Transmitted from Ignition Key / Coil Antenna Circuit Malfunction
DTC 41: ECM Not Registered
DTC 42: Serial Data Circuit Malfunction (between Immobilizer Control Module and ECM)
DTC 43: ECU Code Not Matched
ENGINE:
ENGINE:
BRAKES
Air Bag System
